How long of a screwdriver do I need to open this calculator?
This is a “new to me” calculator I just got. The reason I need to open it is there was a prior battery leak , as I have found some evidence of :-(. This isn’t a deal breaker for me because it looks like it was cleaned well, but I want to open it to see if there is board damage. It’s been working fine for years as far as I know, but it’s better if I open it and make sure myself. It’s probably okay, but it’s more so I have closure on the state of the board itself. I already replaced the backup battery (LR44) as a precaution because it came with the original NL battery TI uses.
I tried using my old style 64-bit driver kit to get in (it needs a T6 Torx) and it’s too short. As such, I need to know if I specifically need a standalone driver to get in or I can get away with a bit set with the right length. I figure the calculator experts here can tell me if I can get away with long driver bits or if I’m stuck without a standalone driver.
Hopefully this helps, but here’s a photo of the length I’m dealing with:
I’ve never worked on a calculator as I’ve always had disposable ones like the TI-30X IIS (and many, many 4 function ones), so I’m not clueless but I’m also not armed with all the information I would prefer having as I’m about to open a $100+ calculator.
Update (2/27/19)
The good news is the leak didn't affect anything. It's only cosmetic and the board survived. Just needed a good cleaning :-).
Esta é uma boa pergunta?
