Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
423 Perguntas Visualizar todos
I charged my Battery And now My Car horn just Honks & wont stop!
Honda Accord 2002
The Story:
I disconnect my Battery to charge it( since I’m currently having a problem where the battery is dying p.s its a new battery :/ This battery may be a little bit bigger for this car. ) When I reinstalled the battery and hooked up both terminals The car started honking at me off and on continuously. I haven’t really had a chance to work on this problem and was wondering if any of y’all have any ideas although I have confirmed cranking the car dose not fix anything. All Help is Appreciated! ~Wessi
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Most modern vehicles will exhibit this behavior when you disconnect and reconnect the battery. The fix is as simple as using the key or the remote lock fob (if you have electronic door locks) to lock and unlock the car doors one time this will usually silence the horn honking.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks for the Tip @professorc. I will try your suggestion and let you know how it goes. Although I'm not exactly sure that is the fix 2 my problem
por
Did this work? I got a new battery and since they it will honk when off periodically. This has been going on for 2 months. I checked the batteries in the FOBs and they are all fine for my 2015 Kia Soul
por
Thank you. It worked perfect
por
For some reason my key fob(panic button) didn’t work. I read some in the owners manual that unlocking the driver side door would turn off the anti-theft system. And it Did!
Pontuação 1
1 dos comentários:
What make/model vehicle (might be useful to someone else)?
por
Adicionar a sua resposta
Wes Ford será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 182
Últimos 30 dias: 892
Duração total: 29,852
