Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Proper way to reattach WiFi cables?
I’ve recently encountered a problem when trying to reassemble my MacBook Pros Airport card, I got it to fit in the slot on the logic board. But my problem now is reattaching the wires. For me it seems they don’t want to stay down very much and a lil tap knocks them off again. Is there a good and easy way to go about attaching them again?
I’ve included a couple pictures of the board and wires.
Update (02/12/2019)
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Take a picture of the cable ends from the top and bottom
por
Sure thing, I’ll go do that
por
Adicionar um comentário
2 respostas
Solução escolhida
The antenna connectors are annoyingly tiny. Make sure you are routing and connecting them in a manner that doesn’t stretch or strain them, or else they might be more prone to snapping. Use a nylon prying tool to properly place and then fasten them to the Airport card.
They should be connected in the following order from right to left: antenna with short piping-antenna with long piping-antenna with no piping.
Also inspect the antenna connectors to ensure they aren’t flattened out and/or damaged by pressure applied to them in the reattachment process.
Esta resposta foi útil?
Pontuação 2
3 comentários:
A photo would help - when working from right to left which side is the top?
por
Presumably one holds the card with the writing the correct way up and the three connectors on the bottom and then work from right to left.
por
What do you do if one of the clips pulls off the wire?
por
Looking at the connector image it looks like they are a bit bent (out of round) carefully squeeze them so they have a bit more tension.
Pontuação 1
6 comentários:
The antenna connectors seem fine to me.
por
@danielbraun - look as the shield gaps some are a little large
por
@danj I don't know man, still can't see it! Am I going crazy?
por
Think it like a drill collet that clamps around a drill ...
por
I get the mechanism, I just don't see any damage in the photo he posted
por
Exibir mais 1 comentário
Adicionar a sua resposta
Wolfe Hunter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 29
Ao todo: 1,686
