Why does my iPhone X show vertical Lines?
So after a drop my micro and disolay start not working properly
so my question now: can i replace the screen with a new LCD and will it start working normally again?
best regards
Esta é uma boa pergunta?
best regards
This is your answer - this is common especially in the iPhone X. Now although there is no signs of physical damage this can be caused by excessive pressure or even a faulty screen so you need to take it to apple.
Esta resposta foi útil?
So would a screen replacement fix it?
yes correct. 100% screen replacement. please mark question as answered.
The display and front microphone are part of the same module, so assuming the connectors of the display assembly to the logic board didn’t damage in the drop, a display replacement will fix your issue most likely.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 5,435
