Just upgraded the SSD of my MacBook Pro, but there's a problem
Hi!
I just swapped the SSD on my Macbook Pro retina early 2015, following your guide: MacBook Pro 13" Retina Display Early 2015 SSD Replacement
Now, looking at the step 4, I had a problem with that plastic cover/adhesive, because it was loose, it feels like it was coming off.
I fear it could fall, causing damages to other components.
Can I remove it permanently?
Esta é uma boa pergunta?
3 comentários
It's not well glued. You could just get some double stick tape. You do want to hold it in place to protect the connections from shorting out.
por Dan
I'm trying to decide whether to buy a double stick tape or a glue, like this one: https://www.amazon.com/MMOBIEL-Multipurp...
What do you suggest?
por Manuel
I would go with the tape, you don't want to anchor it so you can't remove it later
por Dan
