iPod A1213 When powered on shows only the “itunes” picture
when powered on the ipod A1213 shows itunes picture - should i reset ?
Esta é uma boa pergunta?
ugyen try to hold down the home and power buttons at the same time until it shuts down and reboots. This should take it out of recovery mode. the other thing you can try is to download iReb from here and see if you can kick it out of recovery mode. Good Luck
Esta resposta foi útil?
Have you managed to successfully restore your iPod using iTunes? That screen usually shows up only if your iPod's firmware is damaged in some way or another.
A restore will usually get it working again, but if it still shows up even after a restore, your iPod may have another issue that may need higher up help.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 4,147
