Ir para o conteúdo principal
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Perguntas Visualizar todos
macOS HFS formatted external HD won't mount
I have a 1TB from an 2014 iMac that died. I have put the HD into an external enclosure in order to migrate to new computer. Unfortunately, the HD will not mount on the new computer. Running Disk Utility’s Repair Disk on the external HD comes back saying that the Volume is good, but the drive refuses to mount. I’ve tried a number commands in Terminal, tried DiskWarrior and Disk Drill (which allowed me to at least recover the Volumes files) but the HD still will not mount. Help!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Is this a 3.5" HDD? Does the drive case offer an external power option?
If it does you'll need to use it. 3.5" HDD's pull more power than a 2.5" and can have issues when they don't get enough power (older drives more so)
por
No this is a 2.5"drive in a 2.5"inch SATA enclosure.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
My bet is that you have installed High Sierra or Mojave on the internal SSD drive and it has been update to an APSF format. This format now has problems recognizing external GUID formatted drives.
Esta resposta foi útil?
Pontuação 2
5 comentários:
I thought so, too but I've now tried mounting it on an El Cap System and it's still a no go.
por
And for clarity sake: The volume on the external HD checks out fine in Disk Utility but still will not mount.
por
Try doing a GUID secure erase single pass (in Options) Disk Utilities.
por
Is that going to erase the data that is there?
por
Of course, and securely.
por
Adicionar a sua resposta
Roger Clay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 79
