liquid damage with my lenovo ideapad 110, Keyboard power button isn’t
There is a liquid damage with my lenovo ideapad 110, Keyboard power button isn’t working, how can I turn on my laptop?
Esta é uma boa pergunta?
Hi @telecompunch ,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the PCs operating design and could damage the components.
First do not attempt to turn on your computer and then you need to remove the battery as soon as possible from the computer to minimize further damage.
Then you need to dis-assemble the rest of the computer and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA.
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the computer might possibly work correctly again.
What is the full model number of the PC?
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 550
2 comentários
Hi @telecompunch ,
This forum is for helping people, not for advertising your products/services.
Please refrain from doing so.
por jayeff
Actually I have done all the cleaning work, I was able to start my laptop using Lenovo Button and I started working fine (Power button isn’t working because of keyboard)
I tried to start it again with Lenovo button but its not working, how can I start it without power button again?
por telecompunch
