Ir para o conteúdo principal
Repair guides and disassembly information for laptops manufactured by ASUS.
2523 Perguntas Visualizar todos
Laptop won't turn on (No fan spinning , No screen)
Hi everybody!
I have an ASUS X540LJ laptop for 2 years and some days ago I tried to apply some Thermal paste (HT GY260) and after I tried to turn it on it didn’t! (I’m not a newbie in computer and I’m absolutely sure I haven’t touched or broke anything on motherboard)
Here are some other information about it:
  • both HDD and Battery LED’s work and batteries are full charge now
  • After pressing power button, the fan moves a very very bit (Like there’s not enough power to spin it)
I know you’re trying to help me but I’ve already tried many possibilities like:
  • Removing batteries , using external display (VGA and HDMI) , testing the motherboard without any batteries, discharging capacitors, USB sockets have power (I charged my phone with USB) , the fan and LED are just fine and work properly (I’ve tested them both)
One told me that maybe the BIOS is the problem, but I’m sure if it’s all about BIOS, the fan should worked and something has to show on the screen when the laptop is on.
I really need your help!
Thanks
Esta é uma boa pergunta?
Pontuação 0
4 comentários
I know this is an old post but I'm facing the exact same problem right now. How did you fix it?
por
Hi @Ghaith Hatamleh
Better to ask a new question so people will see it.
por
Hi Ehsan, im having the exact problem that you describe in this forum. Did you find the solution or what the problem was. It would be very important knowing your experience to add further information to my case. Thanks in advance. Greetings from Chile
Diego
por
Oh hi :)
Actually at the end, I realized my CPU was dead that time. I hope it is not the same case for you but I gave up on it...
por
Adicionar um comentário
3 respostas
Solução escolhida
Normally when you see computer start for second then stop, it’s a CPU or RAM issue. Try re-seating the CPU and re-applying thermal paste. When finished dump the CMOS. Also try testing with different ram sticks if you have some.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank you Alec for responding.
But it doesn't turn on for seconds. It turns on and CPU getting warm after seconds. But nothing else happens.
CPU, GPU and also RAM are onboard but I've tried to re-program the BIOS and using extra RAM. Didn't help... :(
I checked the voltage of Fan socket and it has exact 1.8 V !!
I would be really glad if anything came on your mind with these new information on this problem.
Thanks!
por
Did you CMOS dump? Take out the CMOS Battery (3v Lithium Battery) and the laptop batter. Unplug the charger. Hold the power button for 30 seconds, then put the battery back in and try to boot. If it still doesn't work, and you're sure the CPU and RAM are fine, then the motherboard will need to be replaced.
por
CMOS has no battry on this motherboard.
Yea I think I have to buy a new motherboard. But I'm wondering what's the matter with it ! I talked to many engineers and it doesn't look that they've faced such problem before...
por
Have you checked the fan?
Are the blades clean.
Does it spin freely when power is off?
Pontuação 1
3 comentários:
Fan works fine and I've checked it with external power source. No problem
por
Just curious. Why did you apply the heat paste? Was it over heating? or what?
In my experience it could also be a ribbon cable not properly inserted. Sometimes they are tricky. Too much heat paste was one problem once.
por
I opened my laptop to clean it. Also opened the heat sinks and realized that it was cleared. I closed everything back and worked fine. Some days later I tried to apply thermal grease...
There was no overheat.
On the motherboard there are no ribbon cables (Just for the keyboard)
por
Have you tried unplugging and reconnecting the power cables to the battery?
have u tried using a diff battery?
is the battery or it’s cables damaged?
is connectors on the mobo for the battery damaged?
if nothing still with these then I’m lost. Because normally as the first answer said that blip of power and then off means it’s a component being seeded improperly. But if not that then it’s either the battery or the PSU which in this case is irrelevant.
So im lost. U could check the front and back of the mobo for blown components or damage to the board. Perhaps it got corroded somehow.
Either way that’s a toughy best of luck mate.
Pontuação 0
1 comentário:
Thanks. I've checked those things before...
por
Adicionar a sua resposta
Ehsan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 103
Duração total: 14,289
