washer won't ring out all water in clothes
after rinsing , during spin cycle, after won’t ring out all the way as it should. Leaves clothes sopping with water
Esta é uma boa pergunta?
Washing Machine Drain Pump Clogged or Faulty. If your washer will not spin out all water and clothes are still wet, the drain pump might be clogged with debris or possibly faulty. ... Check these areas and remove anything that may be clogging the draining system on your washer.
Esta resposta foi útil?
How do you drain the washing machine?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,980
