Ir para o conteúdo principal
Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
battary so fast finish , phone 2 year ard
may i ask what happan P9 battry so fast donw 30 -50%
2year maybe like that , my freirnd same problem with me
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Your battery might be old or damaged.
You should visit a huawei support or go to a repair shop the change the battery.
Esta resposta foi útil?
Pontuação 0
@chenminjin82771 just for clarification on this old question. This issue could be caused by a bad battery. Replace the battery first then re-evaluate. No reason to have anybody else change the battery for you. After all, the goal for iFixit is to empower you to repair your own device, not to send you away to spend money on having it fixed.
Use this guide Substituição da bateria do Huawei P9 to repalce the battery.
Pontuação 0
Adicionar a sua resposta
chen min jin irwin chen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 82
