Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1517 Perguntas Visualizar todos
MacBook Late 2006 boots to white screen, but works on external monitor
I recently swapped the display in my Macbook Late 2006. It was cracked and I found a cheap working display on eBay . The Macbook boots okay but the display remains white. I connected an external monitor and the Macbook works fine with that.
Do you think it’s a faulty display?
Or is it possible I have connected the display cables incorrectly?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
1 Resposta
Pergunta Mais Útil
Sounds like you got the wrong display assembly. While they look the same they are not the same!
Imagem de MacBook 13.3" Santa Rosa/Penryn Display Assembly
Produto
$299,99
Imagem de MacBook 13.3" Core 2 Duo Display Assembly
Produto
$299,99
Esta resposta foi útil?
Pontuação 2
Comentários:
Ok thanks. I’ll have a look.
Is there a way to check the display part number from System Profiler or using an app?
por
Plug in your systems S/N into here EveryMac - Lookup it will tell you the exact model you have as they both look the same.
Basically, the Intel graphics services (Intel GMA X3100 & Intel GMA X3100) is what defines which display is needed. As the signaling is different enough that each needs a unique display assembly.
por
Adicionar a sua resposta
Matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 28
