Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5s doesn't recognize SIM Card
Hi there everyone,
I recently bought an iphone 5s which doesn’t recognize any SIM Card put into it. The strange thing about it is that the iPhone doesn’t ask for the SIM Card in the first place. My usual experience with iPhones is that, if you dont have a SIM card inside, there will be a notification telling you that. This time around there’s nothing, which is why I wonder if my problem is possibly slightly different to the normal SIM Card not working one. Maybe its a software error?
Thanks,
Minas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There is a “switch” built into the SIM card reader to detect the presence of a card. Normally, the phone should notify you if a SIM card is not present, as you suspect. So the fact that you are not being notified leads me to suspect an issue with the SIM card reader. You could open up the phone and take a closer look at the reader to see if there is any internal damage. The reader can be replaced but it requires a micro-soldering repair.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Hi and thanks for the help! Could you clarify what the "switch" exactly is? Is it a physical switch that I can toggle? I'd rather not open up the iphone, but will if I have to.
por
Inside the SIM reader, an inserted SIM card forces a disconnect between two metal contacts.
por
Adicionar a sua resposta
Minas Mayth será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 869
