Ir para o conteúdo principal
Is it possible to get under 100% max cap after a battery replacement?
I replaced the battery of my iPhone 6S. It had 75% max cap. and my question is if it is possible to get under 100% after a battery replacement cause I don’t want to replace it again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Max capacity will always deplete over time. The aftermarket batteries will drain and deplete faster so make sure to get the battery replaced from a reputable store or buy a good quality battery.
Esta resposta foi útil?
Pontuação 2
check this post [iOS 11.3] Battery Health Beta - No Change after Replacing Battery
Pontuação 0
2 comentários:
That isn’t what I was looking for but thanks.
por
if you read it all there are some solutios. In your case if the battery you bought is bigger(more mAh) can be the reason. Or if it is not certified apple battery
por
Adicionar a sua resposta
Ruben será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 59
