Pular para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1474 Perguntas Ver todas
I have hard drive problems, how to test drive to board cable
As title says hard drive problems, disc utility can't repair. I put it in an external dock and booted from install dvd and disc utility says all is well. This drive was brand new a month ago. I ran disc repair and am now in the process of installing os 10.6. If it installs, and it looks like it will, how do I test the hard drive cable and plug?
Thanks Walt
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Solução
Solução escolhida
The only way to test the hdd cable is to replace it with a known good one and see if there is a difference.
Even a little shock can damage a spinning drive
you could try to erase the hdd and reinstall the os
You can find a hdd cable on eBay
Esta resposta foi útil?
Pontuação 1
Comentários:
I did get the OS installed on the same hdd, so that's definitely not the problem. I used a usb hd dock and booted from the install dvd. It boots and works from external dock.
por
Although it loaded, it now has the dreaded beachball. It freezes with the least provacation. I opened activity monitor and it showed hardly any cpu activity, like a .6 for system. If I click anywhere else it freezes and I need to force shutdown. There is no hard drive internally so I'm guessing it is just too much for it through usb. I'm 99% sure the root cause is the drive cable so I'll do that as soon as I can. Hopefully that cures its ills lol.
por
Adicionar a sua resposta
Walter Lawler será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 36
