Ir para o conteúdo principal
Repair guides and support for your Philips TV.
20 Perguntas Visualizar todos
The television sound disappeared
The television voise stell of however I disconnect the cable of the outer speaker form the tv
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Could you explain more clearly what you have done to fix the sound from your TV?
If necessary edit the question (click on Options > Edit) and write the question again in your own language as your current question is difficult to comprehend.
Also what is the model number of your TV?
por
Adicionar um comentário
1 resposta
I’ll wager it still senses the external plug. Insert and remove the plug several times to scrub the contact.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
nadermostafam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 40
