Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Perguntas Visualizar todos
iPad 6 screw set.. help!
Purchased an iPad 6 in a partial state of repair, and it’s missing the four #00 4.3mm screws holding down the LCD, one #000 2.3mm for the battery connector, and three #000 1.4mm screws for the display bracket. I have been searching for hours online for a screw set and I totally can’t find it for the 6 or 5, and earlier models don’t have the right screws. Does anyone know where I could source a set or find more specific dimensions for these screws (thread length/width)? Much appreciated.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Don’t look on google for “iPad 6 screws, instead figure out the screw type you need and look those up. That is significantly easier to find. The screw set that @sammyzhang commented earlier should work.
Esta resposta foi útil?
Pontuação 2
Did you get a set? I can’t find any.
Pontuação 0
I’m still looking myself. It is amazing how no one sells these atm
Pontuação 0
2 comentários:
I finally found that they can be ordered through Genius Phone Repair. $1.24
por
Adicionar a sua resposta
Evan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 30
Duração total: 1,596
