Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1696 Perguntas Visualizar todos
My playstation turns on, it beeps and the light appears then its off
it turns on for like a second then turns right off then you cant turn it on again unless you turn the power off at the wall and press the ps button on your controller.
please help
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi Kris. Does the Console have any notable history of drops or of water damage? Are the vents filled with particularly heavy deposits of dust? Any of these answers may point closer to a solution, but PS4 repair can be pretty open-ended if the cause is unknown.
If you have hours, and I mean many hours of spare time and would like to troubleshoot this yourself, I recommend watching some of the PS4 YouTube videos by Andrew Paul. You will also need to get yourself a set of security torx screwdrivers to even begin any PS4 disassembly.
It definitely is worth testing a new power supply on your console, if only because so few screws are required to swap the PSU and you don't have to take out the motherboard to get to it. The power supply is not *very likely* though. A dead power supply would mean no light and no beep. So in your case, it could be a failing power supply. Maybe you can purchase a new PSU from a seller with a good return policy…
In my experience, consoles like yours usually have a complex motherboard problem. However that's where 50 hours of free Andrew Paul videos come in handy!
If you don't want to deal with this yourself, call around to the local computer repair shops and cell phone repair shops specificly asking if they work on a lot of PS4's. You don't want someone with no experience simply taking a heat gun to the motherboard “because they saw it in a video". That type of troubleshooting can only make a board unrepairable. In most cities, the CPR Cell Phone Repair franchises either fix PlayStation 4 in house, or they escalate the ticket and ship them in to CPR corperate.
Just keep in mind a few things: you can go on OfferUp or Letgo to buy a used PS4 for only $150-200 if repair is too much trouble. If repair is too costly, you may be able to sell your dead PS4 to the shop for $25-$50. If the motherboard really is dead, don't expect a shop to offer you a lot of cash for the box. It may have a lot of $50 parts inside, but they have no way of knowing the history or condition of those parts or if they will actually need them in the future. Take whatever cash you can get if it really isn't fixable.
Esta resposta foi útil?
Pontuação 1
2 comentários:
it's cheaper buying a new one rather than fixing it
the labor costs more than the parts are actually worth
costs around $300-$400 getting it fixed
por
thank you for your help, greatly appretiated
por
try to find out whats wrong with it and get that fixed
Pontuação 0
Adicionar a sua resposta
kris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 414
