Ir para o conteúdo principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
20 Perguntas Visualizar todos
Won't start up, stuck in restart
Phone was fine, shut off & wouldn't turn on. Got it on and now is stuck in restart mode
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Best to try and reset the phone:
  1. Power the device off.
  2. Press and hold the HomeVolume Up, and Power keys.
  3. Continue holding the buttons even if the Samsung logo appears. The Android system recovery menu will appear if this was performed correctly, and the keys can be released.
  4. Press the Volume Up or Volume Down key to select wipe data/factory reset, and then press the Power key to make your selection.
  5. Press the Volume Up or Volume Down button to select Yes ��� delete all user data, and then press the Power key to make your selection.
  6. When the reset is complete, press the Volume Up or Volume Down key to select reboot system now, and then press the Power key to make your selection.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you, have tried. Doesn't work unfortunately. Any other ideas please let me know. Thank you again
por
You can try and flash the phone using Odin.
NOTE: flash at your own risk!
https://forum.xda-developers.com/s7-edge...
por
Adicionar a sua resposta
Felicia Kraus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,040
