PS4 Eject Button not connecting - Need Help
I’ve recently taken apart aPS4 to complete some cleaning and the replacement of thermal paste and the addition of a new Blu-Ray ribbon cable.
The machine boots up and works fine except the touch sensitive eject button does not function.
I can eject via the PS4 interface and I can also eject via touching the small copper plate when the cover is off, so I am 100% sure this is an issue with the button itself.
On closer inspection it looks to have been bent back a little and whilst I have tried to bend it back I fear it’s not touching the copper plate.
However I am confused how this works - should this silver prong be touching the copper plate at all times?
If so is it worth adding some solder or tin foil for a possible way to guarantee contact?
Esta é uma boa pergunta?
2 comentários
Anyone? Happy to pay for help.
por J P
I have this same issue, but I wanted to ask you if you did anything and did it help? Because I need help and I can’t find answers anywhere
por Leonardo Chavez
