The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
268 Perguntas Visualizar todos
I press the power button it doesn't come on
The lights comes on and when i press the power button it doesn't come on
Score 1
Adicionar um comentário
Kits de reparo de android
A new screen or battery is one kit away.
Comprar agora
Comprar agora
2 Respostas
Chosen Solution
Try 1 &2 first as they are the most common
Solution 1:
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse
Solution 2:
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Solution 3:
Door Switch
Solution 4:
Drive Motor
Solution 5:
Main Control Board
Score 1
Most Helpful Answer
carpenterkathy05  download the tech sheet from the bottom of this page Kenmore Elite HE3 Dryer and try to get into the diagnostics mode as instructed on page 1. It will allow you to narrow down what may have failed and it will allow you to check the door switch as well. Let us know if and what error code you are getting.
Score 2
Add your answer
carpenterkathy05 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 53
