Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
Esta é uma boa pergunta?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
Esta resposta foi útil?
It might be much easier to just buy a new cable:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 107
1 comentário
Hi. Maybe you could solder it but it won't be easy.
por Csendes Csaba
