iPod shut down when is playing
OK, i'm **#*#@ off...
the problem began when i quote this:
Some times the current track skips to the next one
So now this piece of sh***t is sleeping or something, when is playing suddenly turns off or something like that, it came back if push any button an then go as if nothing happend and then do the same thing in almost every 2 o 3 songs.
I have done the thing of reset, format in Windows, format in Mac, run Disk Utility on it, pray to the holly bean, etc...
So anyone who knows if the piece of sh***t has repair?
or just use it as a external disk
Esta é uma boa pergunta?
Mauro, you sounds rather angry :-) what exactly did you do before the error started? you quoted an older question but did not say what you did. Convert VBR to CBR?
por oldturkey03
D'oh! (sorry about that...)
I change the files from VBR to CBR... in that time it work.
Now I click on the SUMARY option "CONVERT HIGHER BIT RATE SONGS TO 128kbps AAC" on the ITunes and see what happen
if that doesn't work i'll have a nice and expensive piece of SH***T
por Mauro
It is not your iPod that is at fault here. I would try to convert a few songs back to the previous bit rate and see what happens, the skipping occurs due to the bit rate. Its probably more an itunes and bitrate error than the iPod.
por oldturkey03
