Ir para o conteúdo principal
Samsung LED Smart TV Red Light Blinks 5 Times UN60H6350AF
I have an UN60H6350AF Smart TV that when pressing the power button the red light blinks 5 times and goes out.
I have opened up the TV and when I unplug the main board from the power supply I see the LED light come on. Makes me believe the power board is fine. How do I determine if I need to replace or fix the Main Board or T-Con Board?
Thanks in advanced.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
I have the similar problem I have changed the t-con board and the power board with new ones and still not functioning
ng any help would be great
por
In case you;re having same issue, here is a helpful guide: https://www.tekpip.com/samsung-tv-red-li...
por
In case you're having same issue, here's a guide: https://www.tekpip.com/samsung-tv-red-li...
por
Adicionar um comentário
3 respostas
Solução escolhida
I replaced the Main Board and everything worked! Thanks.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
@masterethan
it’s a bit like guessing. I would check to see if you have power on the BL-En on your connector. That is the power to enable the backlight by the power board. If you have that then it is most likely the t-con board. Check the fuse on the t-con board for continuity and voltage. You should get ~12V on that.
Pontuação 2
1 comentário:
When I unplugged the main board from the power board, the screen lights up and I can see the light coming through the screw holes as well. With that I assumed it's either Main Board or T-Con, but wasn't sure how to determine which one it was. I'll find and check the t-con boards fuse and voltage and see if that reveals anything. Thanks.
por
In case you're having same issue, here is a guide: https://www.tekpip.com/samsung-tv-red-li...
Pontuação 0
Adicionar a sua resposta
masterethan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 56
Duração total: 9,373
