Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
No video dislay or backlight Diagnostic LEDS 1,2 lit, LED 3 flashes
My Intel Mac has died! No video or back-light. I get the start up chime and the HDD sounds like it is doing something.
Diag LEDS 1 and 2 come on and LED 3 flashes momentarily.
I can load/unload CD's, and the power button seems to put system to sleep and pressing a key seems to wake it up too.
I have checked that the VGA card is not obviously damaged.
tried resetting the SMC and the PRAM to no avail (not surprised really)
Sounds like either the VGA or the Logic boards have died!
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Apple iMac "Core 2 Duo" 2.4 20-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB323LL/A - iMac8,1 - A1224 - 2210
or the 2,66 GHz model
por
2.4GHz - HD2400XT VGA
por
the VGA is Kaput! Guess this baby is destined for the scrapheap...
por
richdave, Here is an excellent forum on modding/hacking video chip firmware for the Mac.
por
Thanks ABC Cellars.. not sure if I will find a solution there but it will be quite a few hours of interesting reading...
por
Adicionar um comentário
1 resposta
Solução escolhida
This is straight out of the book.
If LEDs 1 and 2 are
on and you heard the
startup sound, but
LED 3 is off, video
card may either be
installed incorrectly
or need replacement.
Esta resposta foi útil?
Pontuação 4
4 comentários:
+ but not everybody has the book :-)
por
I realize that, I just didn't want richdave to think I made it up ;-)
por
Thanks Mayer. I too have the book! I suspect that the VGA is Kaput! I'm toying with buying a non mac Mobility Radeon HD 2400 and seeing if it will work. Same form factor and I suspect the pin outs are standard. Firmware on the card is my main concern.
por
Well I tried an ext monitor and it too is blank... not surprised really.
por
Adicionar a sua resposta
Richdave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,841
