Phone dies on new full battery after few seconds
Hi
I just replaced the battery on my iphone 3g with a 1600mah version. Upon restarting, everything is fine, but the phone shuts off after only a few seconds of use, even when showing full battery. I have charged it for about 16 hours, it shows full charge but still shuts down after about 10 seconds of a phone call. It gives a short rotating white ring, then dies and cannot be restarted (does not show flashing battery logo). When I connect the adaptor, it restarts with white apple logo and is fine (although a couple of times it needed a reset of date and time). Each time it has restarted, it shows full battery.
But ...
It doesn't do this when connected to the power adaptor.
Everything else seems fine - docks ok.
Have I installed a dud battery, or does it need some kind of shock to wake it up?
Hope someone can help me.
Regards
SimonC
Esta é uma boa pergunta?
2 comentários
I think you are right. I am ordering a new one, so hopefully that will sort things out. I am not too happy to take the phone apart to put the old battery in again. Those connectors are beasts for my clumsy fingers, so I will wait for a new battery and hope that it is a good one.
Thanks for your reply. I had guessed it was a bad battery, but just wondered if I had forgotten do so something and needed to get a second opinion.
SimonC
por SimonC
Best of luck Simon, just go slow and you should be fine.
por hectordtruong
