Logic board bracket ( flex cable connector to lcd) broken
Is there a fix for a bracket breaking on a logic board? It connects a flex cable to the lcd. If there id,. How or what would I use?
Esta é uma boa pergunta?
If you are referring to the flap metal connector on the logic board, that’s soldered to the board itself..the only way it can be replaced is to solder a good one back in place. You’ll need a reputable lab into microsoldering for such job..better if with some experience with Macs as the retina Macbook is not a particularly easy machine to deal with.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 100
1 comentário
Please be more specific as to what part you are referencing. Adding a picture would really help us to give you a correct answer.
por mayer
