putting the glass back on
how do i get the glass to stay on after replacing the digitizer?
Esta é uma boa pergunta?
Hi bryant,
After pluging the digitizers cable in and wiping the lcd and inside of the digitizer, just place it down gently ontop and as long as all the clips are not bent then just slowly apply even pressure down upod the edges, keep doing this working your way along the edges and eventually you will start to here clicks, this is good. If however you apply to much pressure in one place and click that side in there is a chance that the screen will crack again (this happend to me). so nice even pressure. :)
hope this helps.
Mic
Esta resposta foi útil?
Did it work well for you?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,012
