How can I enter to the service menu in toshiba 32hv10e?
TItle.
I’ve tried everything I was able to find on the internet.
Thank you!
Esta pergunta é pertinente?
TItle.
Thank you!
ronben20 until we know what you have tried, look at these solutions.
"Most Toshiba flat screen LCD and LED TVs use the mute button method for accessing the service menu. To access the menu, set the volume to minimum and press the "Mute" button twice on the remote control. Next hold the mute button down and press the "Menu" button on the TV set to launch the service menu. You can exit the service menu by turning off the TV set." If no luck with that you can always try this:
"Toshiba LCD Service Menu Code”
Press the {MENU} button on the remote.
Highlight the "Picture" icon.
Press the {9} {3} {0} {1} buttons on the remote.
{OK} button will access/navigate through modes
{VOL +}, {VOL-}, {P+} & {P-} buttons move through options and change values
To exit, press the {MENU} button."
Esta resposta foi útil?
Tried the mute button no luck
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 111
Duração total: 20,365
6 comentários
Do you mean the BIOS menu?
por [deleted]
It's a TV so I think It's a service menu.
por ronben20
ronben20 save us some time about telling you something you may already have tried. Let us know what "tried everything" this entails.
por oldturkey03
I've tried those:
1.
Tried with {4} {7} {2} {5} too.
2.
Press and hold the {VOL -} button on the TV and the {9} button on the remote control for few seconds.
{CH+} & {CH -} buttons select options
{VOL+} & {VOL-} buttons change values
To exit, press the {MENU} button or turn the power off.
All the other solutions that I've found - need buttons that I don't have on my TV.
I only have VOL-, VOL+, CHA-, CHA+ and power button.
Thanks!
por ronben20
i want code of model l32l5865ea
por deyaa hekal
Mostrar mais 1 comentário
