My Dualshock keeps tuning on and off
So one of my DS4 controllers is turning on constantly it conects to the ps4 and everything but after 10 seconds it turns off and turns on again. What could it be?
Esta é uma boa pergunta?
I think the batteries in your controllers are going kaput. I would order one replacement battery and see if that solves the issue with one of the controllers, then I would order as much as you need to fix the other controllers with similar symptoms.
Esta resposta foi útil?
@ajcooke01 has given u the best answer
Hey there ! Thank you for responding quickly. Is there a way to check this with a multimeter? I don't want to spend money on a battery in case something else is wrong,
@robsferic Personally I have never used a multimeter and therefore I cannot suggest anything.
I hooked the controller to the Pc with a cable and figured it out the home button is stuck. Thats why it turns on and off constantly. Can someone tell me why is this happening?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 62
