Ir para o conteúdo principal
Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
20 Perguntas Visualizar todos
1994 vauxhall corsa/ holden barina misfiring
my Barney the Barina (that I have owned since new) decided to start misfiring if it rained… quick spray of wd40 on the distributor cap and he ran like the new again. Recently had some rainy weather, husband notices some grit in cap, sprays wd40, seems to be ok but then stalls/backfires/dies. Check distributor cap-burned out rotor, damage to cap. So far 1) replaced distributor cap, & 2)replaced rotor…still misfire. 3) replace spark plugs… still misfire 4)replace HT leads, still misfire. Barney starts, but is running rough. any Idea? @oldturkey03 ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
thanks for all the helpful replies :-)
the mobile mechanic declared the problem to be the ECU… I wasn’t convinced. Took it to the real mechanic who found that the timing belt had jumped a few teeth.
lesson learned… when the husband says he doesn’t need to check the timing belt because that couldn’t be the problem?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
pollytintop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 548
