Ir para o conteúdo principal
Why is my phone still dying
i had a problem with my phone because It would die if it wasn’t connected to charger and I changed my phone battery like 2 days ago and it’s doing that thing again. What is wrong with it,and what can I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Sounds like battery needs replacing. Phone shutting off quickly after taking it off charge is a common symptom of a bad battery.
Substituição da bateria do iPhone 6s
iPhone 6s Battery
Imagem de iPhone 6s Battery
Produto
iPhone 6s Battery
$29.99
Esta resposta foi útil?
Pontuação 3
If you replaced your battery and it is still not charging or holding charge properly, most likely you have a faulty Charger, charging cable, charging port or charging IC is bad. Using a multimeter, measure the voltage on the logic board side battery connector while it is plugged in and test if it is receiving a charging voltage or not. In a majority of cases, it seems that Tristar goes bad or Tigris goes bad and needs a new IC chip to work again. You could always charge a battery up and then try it to see if it powers on and works properly to verify this without a multimeter
Pontuação 3
Adicionar a sua resposta
Isaac será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 36
