Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
397 Perguntas Visualizar todos
Is the Late 2013 display interchangeable with Mid 2014 display?
Hi there :)
I got a MacBook Pro 15” Late 2013 with working screen and I could buy Mid 2014 MacBook Pro 15” with damaged display. Can I swap them without any problems?
Can I swap SSD as well?
Thank You
Bart
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
the screens for the Late 2013 and mid 2014 Macbook Pros are the same, so you can switch them.
The SSD is used from Late 2013 to 2015, so you can change the SSD as well.
Esta resposta foi útil?
Pontuação 3
Can you also swap out a late 2013 display to a broken mid 2015? Are all of the retina displays of this MBP model type the same?
Pontuação 0
Comentários:
No, you cant use the 2013 Screen on the 2015 Modell. At least the Camara-Cable dosent fit, im not sure about the LVDS Cable.
por
Adicionar a sua resposta
Bart será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 324
