Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
113 Perguntas Visualizar todos
Where to get high-temperature foam?
I replaced the battery on a Macbook Air, and the battery connector keeps coming loose. I think that the best solution would be to tape a piece of foam on top of the connector, so that when the Macbook is reassembled the connector is pressed into place by the bottom cover. I am worried about the temperature, so I am reluctant to put on just any piece of foam. Does anyone know where to get high-temperature foam, especially pieces that have adhesive backing?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Just use a piece of Kapton (Polyimide tape ) tape on it
Polyimide Tape
Kapton is a polyimide film developed by DuPont in the late 1960s that remains stable across a wide range of temperatures, from −269 to +400 °C. Kapton is used in, among other things, flexible printed circuits and thermal blankets used on spacecraft, satellites, and various space instruments.
Imagem de Polyimide Tape
Produto
Polyimide Tape
$9.99
Esta resposta foi útil?
Pontuação 3
Comentários:
Thank you for the suggestion. I have ordered that and plan to use it. Maybe that is all that I really need. However, I was hoping to get, in addition to that, some foam to provide additional hold-down or press-down force. I know it must exist, because there are pieces of foam inside of the Macbook, on SSD drives, etc. If you or anyone else can suggest a high-temperature foam product I would be grateful.
por
Adicionar a sua resposta
Tom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 53
