Ir para o conteúdo principal
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
79 Perguntas Visualizar todos
Washer drum not spinning
Good afternoon, my washer motor runs and it sounds like the drum is spinning but it is not. I have tried it on all spin cycles and bumping it with my hip. Nothing is getting it to spin I also tried rearranging the load and taking some items out of the load. Still no dice.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@bettyboop8025
if it is a 400 model (give us your washers complete model number) it will be direct drive washer. Check the motor coupler between motor and transmission (it commonly fails) Use this guide Kenmore 400 Washer clutch band Replacement step 4 to check on it.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Bethany Willis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,216
