Ir para o conteúdo principal
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Perguntas Visualizar todos
No more charging. Not even when turned off
My HTC has been working fine till i switched phone companies. Now, not only does it drain battery faster than any cable I’ve tried, the battery still drains faster than it charges even when turned off. I had my phone on the charger turned off for two days now and it only had enough energy to power on. It stayed at 27% and has never gotten back to 100 in months. Is there a way i can fix it or should i just find another phone?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
As a technical advise i would like to mention these steps.I do not know whether you could perform the steps alone but read.
First try hard restting the device
If the problem still the same root the device and flash a custom kernel using flashify APK or another method .
Esta resposta foi útil?
Pontuação 1
Have you tried calibrating the battery? Or changing the battery? That could be a malware or some type of issue like that, you can try replacing the battery, trying a less powerful charger and completely reboot and restore the phone.
Pontuação 0
1 comentário:
phone has been rebooted twice, cheaper to buy new phone than new battery. haven't had the battery calibrated
por
Adicionar a sua resposta
Raven R será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 45
