Ir para o conteúdo principal
Repair guides and support for your Philips TV.
241 Perguntas Visualizar todos
Something wrong with T-Con board?
Recently my TV started showing this dark shadow on one side:
I managed to get it away when fiddling with the left ribbin on the T-Con board, but only for like 5 minutes. This problem returns every time.
What could it be? And is it fixable?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Need model number.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Roan de Graaf  that does not look like a T-con error. It looks like a dim light and a fix for that would be a new power board. Of course, there is always a possibility that this is a bad panel. Start with a new power board and see what it does.
Update (11/08/2018)
Odd behavior for a T-con board but if you can resolve it by moving the hasp on the board, consider changing the T-con. I'd purchase one that could be returned just in case it does not resolve the issue.
Esta resposta foi útil?
Pontuação 1
1 comentário:
No, its definitely not a dim light.. All the backlights are working just fine and when I disconnect the ribbon from the T-Con the screen turns completely white.
I can get it away by opening and closing the latch of the ribbon on the T-Con board multiple times, like sometimes it triggers something to make it right. But that doesn't last long tho.
por
Adicionar a sua resposta
Roan de Graaf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 764
