Ir para o conteúdo principal
Line of business laptops originally sold by IBM and then purchased by Lenovo in 2005. Older models (Pre-XX50) have a WiFi whitelist, so wireless card replacement is not as easy as buying a bulk generic card online.
711 Perguntas Visualizar todos
Backlight does not work when unplugged
Just received a used Lenovo T450s. Problem is, when the charging cable is disconnected, the backlight turns off completely, while plugged in, its fine.
Already wiped the laptop, ran through numerous bios and driver updates, but the issue remains.
I confirmed this is not a battery/power option within windows. I DO need to replace the external battery, as it doesn't seem to charge, but the internal one works great. Just curious if anyone has had this issue, and maybe knows a fix, before I go off replacing the screen/battery.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Have you checked your power and brightness settings
por
As stated in my post, it doesn't seem to be a setting within windows. As far as brightness, brightness shows full, the screen is on, but the backlight is off.
por
Hi Have you tried running the Lenovo Solutions Centre battery diagnostic check to see if the internal battery is OK?
It seems that it is not capable of running the laptop and display backlight by itself without the power connected and as you say that the external battery may be faulty.....
por
Adicionar um comentário
1 resposta
The manual suggests using the ‘Lenovo Settings’ program to adjust power profiles. I know you said you ruled out the Windows power utility but this is a separate program that runs on Win 8 and 10. Sorry if this is redundant.
If that isn’t the problem then it really must be a battery issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
James Bosch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,295
