Item is temporarily unavailable when installing Mac OS El captain
I recently wiped my partition to give this laptop to my dad after I received a mid 2012 MacBook Pro, I had been able to wipe my partition and install a given OS such as Sierra and High Sierra without issue and for some reason while trying to install El Cap it just won’t work. I’ve tried to put the correct date in terminal, sign into iCloud with the given account, attempted to use internet recovery mode (not supported on 2009 models but it was worth a shot). Does anyone have a solution to this? Thank you!
Esta é uma boa pergunta?
4 comentários
What's the error you're getting when the installer fails?
por Alec M
This Item is temporarily unavailable please try again later
por Johnny Luna
Have you upgraded the hard drive to an SSHD or SSD?
por mayer
I can't find any other solutions than the ones that you've tried.
Are you sure you're using the apple ID that was used when you first got the computer?
Also, I saw someone who mentioned that signing in with a different apple ID (not the one that you had originally) worked to fix the issue.
por Alec M
