iPhone 6s Plus weak WiFi signal after being dropped
Should I replace the WiFi IC? Or the antenna?
I heard changing of WiFi IC would disable WiFi function? it that real?
Esta pergunta é pertinente?
Wi-Fi IC (Also known as Wi-Fi chipset) requires micro-soldering to replace the chip and the NAND would also need to be reprogrammed to have the matching MAC address to the Wi-Fi IC.
Weak signal is more likely caused by damaged iPhone housing / antenna cables or connectors.
Esta resposta foi útil?
Hmmm...this is strange...the question that is.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 169
