Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
508 Perguntas Visualizar todos
Trackpad not clicking after some use
The trackpad on my MacBook Pro (13”, 2017, No Touchbar) refuses to register clicks after 30 mins - 1 hour of use. Sometimes I have to press really hard for it to register, and often, as I hold (not press) my finger on the trackpad, it registers as constant clicking.
The MacBook had water spilt on it and the top case was replaced.
Esta pergunta é pertinente?
Pontuação 3
4 comentários
a mi me pasa lo mismo ya lo he probado todo lo ultimo reinstalar el ma os y nada la unica forma que hay de que me vuelva a funcionar es la de dejar el mac apagado durante unos minutos, entonces funciona unos miutos y va perdiendo el click poco a poco hasta que deja funcionar la solucion tambien seria remplazar el trackpad?
The same thing happens to me, I have already tried everything last, reinstall the maos and nothing, the only way to make it work again is to leave the mac off for a few minutes, then it works a few minutes and it loses the click little by little until it stops working, would the solution also be to replace the trackpad?
por
@Oriol Tinez - Lo siento, sí, también necesitas una nueva unidad de trackpad.
Sorry yes, you also need a new trackpad unit
por
okey gracias, pero es original no? porque ya compre un trackpad de otro fabricante olive me parece y me dejo de funcionar hasta el teclado conectandolo y no funcionava el trackpad tuve que volver a poner el antiguo
OK, thanks, but it's original isn't it? Because I already bought a trackpad from another manufacturer Olive I think and it stopped working until the keyboard connecting it and the trackpad did not work I had to put the old one back
por
@Oriol Tinez - Lamentablemente, debe utilizar la parte correcta de Apple [produto vinculado ausente ou desativado: IF123-057-3]
Sadly, you need to use the correct Apple part [produto vinculado ausente ou desativado: IF123-057-3]
por
Adicionar um comentário
3 respostas
Solução escolhida
You should go back to the place you got it fixed if its still under repair warranty. It sounds like they didn’t replace the Touchpad (trackpad). Unlike older models your’s uses a taptic engine for the feedback of the click. Luckily, the part is very easy to replace! MacBook Pro 13" Function Keys Late 2016 Trackpad Replacement. Here’s the part you’ll need [produto vinculado ausente ou desativado: IF123-057-3]
Esta resposta foi útil?
Pontuação 2
Have you got it fixed? I have the same problem and I have never replaced or damaged anything on my MacBook. The trackpad clicking is great when I turn on the device but after 30 minutes it becomes so firm to click. @danj any ideas?
Pontuação 2
3 comentários:
Do you wipe your system with a damp cloth? The cleaner likely seeped into the gaps and into the touch surface sandwich damaging it. These larger Touchpad's are more prone I've replace two so far this year and one person here is also encountering issues as well.
The ones I have fixed all used cleaners often spraying it directly on the system and wiping it off. This offers the window for the cleaner to get where you don't want it! LCD or Trackpad/Touchpad both can get damaged!
I strongly recommend you spray the cloth not the hardware with any cleaner!!
Time for a new Touchpad for you as well...
por
Yeah you're right I guess I need to get a new trackpad... Thank you for your help @danj
por
Hey, the trackpad was working all winter normally, but started acting up again during summer, so I'm guessing it has to do with the leftover liquid from when I spilled it that condensates at higher temperatures. I definitely have to replace the trackpad.
por
I have exactly the same issue
My guess so far that the battery is what pressing on the trackpad.
Because older models had this issue.
Now I am waiting for my iFixit toolkit to open the laptop and see for myself.
Pontuação 0
2 comentários:
And from my guess, it has to do with high temperature.
por
See if placing the system somewhere cooler and hold off charging it as well.
If you are in a humid place, place your system in an airtight bag sucking out the air before you put it the fridge if that's the best you can do.
Did that help?
por
Adicionar a sua resposta
Ivan Škorić será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,725
