Ir para o conteúdo principal
The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
14 Perguntas Visualizar todos
Why won't my roomba hold charge?
I have two roomba 360s. One won’t hold a charge for more then a minute and then it dies, the other aon’t charge at all it says “charging error 3” . How do i fix both of these problems ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
First, turn your Roomba upside down and clean the battery contacts on the base. Unplug the docking station and clean any dirt or debris off the contacts there too. If the contacts are rusty the rust will prevent the Roomba from charging properly. Get an emery board or fine nail file (I used the cardboard type as they are more flexible) and gently sand off any rust. This may get your Roomba charging again.
As this is an earlier model Roomba the battery maybe due for replacement. Even a rechargeable battery doesn’t last forever. Later model Roomba’s have software that won’t let them take non-original parts but yours might not have this issue.
Esta resposta foi útil?
Pontuação 0
I don’t dock mine, I plug it in. Now what?
Pontuação 0
2 comentários:
Battery replacement.
por
This rumba is only a year old and it doesn't hold a charge, what a piece of junk
por
Adicionar a sua resposta
Anglea será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 6,244
