Ir para o conteúdo principal
Entry level Photosmart printer introduced in 2009. Uses HP Tri-Color ink cartridges with a disposable printhead.
14 Perguntas Visualizar todos
Pergunta encerrada
Printer not printting black ink when trying to print Documents...
Hi y’all, the printer I have is actually an HP Photosmart 7520 series, iFixit just didn’t have that printer to select from. I have the printer hooked up wirelessly and when I print test status reports from the printer menu it prints those with black ink just fine but when I try to print a word or text document from my computer it won’t print black ink but will print other colored ink. I tried downloading driver updates for the printer on my computer, resetting settings on the printer and, switching which trays to print from on the printer and so far no luck :( I tried googling the problem online and all I could find was people with problems like not printing black ink period but my problem is it won’t print black ink when I try to print any kind of word or text document. Any help would be much appreciated , thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This is odd. If you are printing a black and white document then change the print job settings to print gray scale.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 511
