Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Battery not charging after DIY repair.
Hi,
My wifi signals were very weak so I decided to replace wifi flex cable. Using ifixit app I read the tutorial and fixed it. I was quite happy but later on realised phone is not charging. I opened my iphone again and checked if all cables are attached and they were perfectly placed. I switched off my phone and connected charger it powered ON but again it wasn't charging. Please help me. And also tell me which cable transfer current to battery. Maybe,I would have dislocated something.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
@aatif667 Do you have a computer running macOS/OS X handy?
por
Yes.. i have macbook pro
por
I put it on charge for an hour now its taking charge. But now comes the other problem. Touch and screen is working fine. But while powering off I can't slide that to power off.
por
Adicionar um comentário
1 Resposta
Substituição da Bateria do iPhone 6
Step 12 shows you the battery connector. Check that connector. You also could have damaged something in the process.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
AATIF ALI KHAN será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 41
