Ir para o conteúdo principal
A line of external hard drives by Western Digital, styled after hardbound books. Available in various editions from Essential, to Premium to World Edition.
31 Perguntas Visualizar todos
My 8TB drive won't stay connected on USB3, but will on USB2
I have two 8TB WD Easystore drives. Both behave the same way. Connected to USB3, both are recognized and work, until there is no activity. Both go to sleep and disconnect. I get “drive disconnected” error on my Mac. I tried connecting them through a USB2 hub and they stay connected. I tried connecting one to the USB3 port on my ASUS wireless router. I set it up as TimeMachine storage. All was well, until the activity stopped. Then I got a “device not connected” error when TimeMachine tried to run again. Any help is appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
If you’re still suffering this problem it seems to be a known issue documented on WD’s site:
WD USB 3.0 hard drives disconnect or disappear when connected to a USB 3.0 hub
Unless this is a common problem with all USB 3 drives I would of said the problem is with the WD drive for which an update should be issued for that, but hey you can try their suggestion.
Esta resposta foi útil?
Pontuação 1
Some WD documents suggest formatting their external drive products to a MAC filesystem type if you have connectivity issues. I realize that is a bad solution if you want the data to be portable to other systems. Also pretty inconvenient if you already have data on it as it sound like you do.
Pontuação 0
I was experiencing the same problem with my new WD 8TB My Book. I found out it was overheating and apparently this causes it to disconnect. Once I changed its location and position to allow for airflow through the vents, the problem disappeared. Hope this helps.
Pontuação 0
Adicionar a sua resposta
Linus D será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 278
