Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1191 Perguntas Visualizar todos
How do I know if I have a Santa Rosa model?
Well, just what the title says. I know I have an Early 2009 MacBook with a 2 GHz Intel Core 2 Duo which came with 2GB of RAM, but i have absolutely no idea whether I have a Santa Rosa/Penryn model or not. How do I know?
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
By the information you have given you have a Penryn. You can go here to find out what MacBook is what.
Esta resposta foi útil?
Pontuação 2
Comentários:
That's right, thanks! The serial number lookup page from mayer confirms that. Thanks guys!
por
Pergunta Mais Útil
The easiest way is to go to the site CAB mentioned: http://www.everymac.com/ultimate-mac-loo...
then enter the last three figures of your serial number.
Pontuação 4
The term "Penryn" refers to the processor/CPU chip, and the term "Santa Rosa" refers to the logic board chipset (several other chips besides the CPU). The Everymac website won't tell you what logic board chipset a Macbook contains, and it also doesn't use the references Penryn, Santa Rosa, etc. A better source for some of these terms is the utility "Mactracker", which can be downloaded from most Mac software websites. The processor in the Early 2009 Macbook is a Penryn (P7350), but the logic board chipset is not the Santa Rosa, which supports only an 800 MHz system bus--since the system bus in the Early 2009 Macbook is 1066 MHz, the logic board chipset is the Montevina.
Pontuação 2
Adicionar a sua resposta
Jamy Mahabier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 4,602
