Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Problem with pression point/spot blue doing screen replacement.
Am i the only one or are you guys encoutering some problems with iPhone 7 LCD also?
Now i’m removing the low retaining bracket to be able to fit in my LCD. Note : This is the OEM quality here in Montreal. (a friend told me that he’s installing the flex cable under the metal plac,but i preffer without the bracket then leaving my flex cable hanging out unfixed).
So,what do you guys do when something like that happens?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
5 comentários
I'm not seeing anything wrong with the screen? I'm on a crappy laptop so might be the reason but still. Is anything wrong, like you can't tap in that spot?
por
Without the bracket he wont feet in and that's a light spot also. Not normal at all.
por
Like subtly brighter or..?
por
In a photo it could looks like its subtly,but trust me it is not.
por
The second photo you can see that the frame aren't touching the body. It is easy to see.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The touch sensor isn’t sitting well, in some repairs loosen the battery plate and ensure it is all the way to the opposite direction of the sensor. Also some say to move the sensor down a smidge? To ensure it fits. Also if there is the foam on top of the connectors to remove it so it has more room.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
DouglasVinicio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 48
