Washer won’t advance past wash cycle
Kenmore Series 500 topload Washer
Washer will not advance past the wash cycle. Will not go through the rinse and spin cycles. It does drain. When it stops at the wash cycle, we then try to set it to rinse and spin and the rinse and spin setting doesn’t work. Turning it to the drain and spin is just fine, it just seems to be a problem with the rinse cycle.
And, actually, there are times that it will complete a full cycle, it isn’t often, but on occasion it’s does a complete cycle by itself.
Esta é uma boa pergunta?
15 comentários
water keeps filling in washer when off....
por ruth godoy
My washer works until it gets to the wash cycle, on the wash cycle it just stops it will not fill with water and will not agitate, but if I manually turn it to drain, and spin, or rinse,and drain. it does rinse and drain and spins but it gets stuck on the wash cycle what can I do to fix this I am a single mom on disability ion a very tight budget? Everything else works on my washing machine is just will not wash it will spin on the drain and rinse cycle it will rinse and drain on the rinse and drain cycle but it will not fill with water agitate it always stops on the wash cycle and will not Advance no matter what cycle I put it on I've tried every cycle on my machine and none of them work on the wash cycle,when it gets to the wash setting it just stops! the wash light comes on and it doesn't go past it?
por Robin Tomlinson
i have had the same problem! I have to manually turn the cycle to rinse and spin and then drain and spin.
por jessica wheeler
My washer is doing the same thing and it was delivered yesterday!
por childspenelope
Yes....mine continues to run even when cycle is done. Very annoying and it has to be unplugged when done or it will run all day until unplugged. Horrible machine!
por allyson trionfo
Exibir mais 10 comentários
