Need repair on our Typhoon H , who can we send it to?
Semi crashed drone , knocked off couple blades , 3 connector bolts for camera , need repair , Best Buy was total bust , whom can we send to for repair or is close to us that can work on it , we are in Hammond,La 70401
Esta é uma boa pergunta?
It was one of the boards inside that is gone I believe (GPS or main). I believe
My email is. gregmacmillan1958@gmail.com
My. Name is. Greg
Unique typhoon h drone
por Greg MacMillan
Hi Greg, if the GPS seems to be Stuck on "Acquiring" on the ST16 Display, the most likely cause is a Faulty Flight Control Module (FC) located on the main ESC Power Distribution Board, this seems to be a very common issue. The FC Module is something you can replace yourself, depending how confident you feel about removing the Top Shell of your Typhoon H, and Unplugging the FC Module, and Plugging in the Replacement, you can find a Replacement Flight Controller here; https://yuneecskins.com/all-products/ols...
por John Mitchell
If you would rather have it Repaired, thoroughly Tested & Test Flown, here is the Link to the Yuneec Repair Services; https://yuneecskins.com/yuneec-repair
por John Mitchell
I sent you an email Greg...;)
por John Mitchell
