Ir para o conteúdo principal
How do I remove my back panel?
I had an UN65MU6290 for 3 months before 1/3 of the screen became darker than the rest. Now the whole screen is dark but there is power and the sound works. My assumption was an LED strip needed replacing but there are no screws on the back to remove. I was able to pry loose the bezel from the top and sides but the bottom will not budge at all. The bottom has cracked in several spots from my failed attempts. Ideas??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Have you seen this video?
Not the same model as yours but perhaps the same way of removing the back cover. View from about 2:30 minutes into the video
Esta resposta foi útil?
Pontuação 3
1 comentário:
It gave me some hints but with his TV the bezel didn't interfere with undoing the clips. The bezel on mine can be bent and moved partially but I was too rough and now need to replace it. At least now I've been able to get to all clips holding the back in place.
Where I am now is the plastic clips holding the last 2 layers in place to get to the LED strips. Every video I've seen so far shows simple plastic prings that can be squeezed and pushed through holes. These are different.
por
Adicionar a sua resposta
ransoma99 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 102
Duração total: 26,043
